So I went and picked up a 1010 crawler with the gas engine and have a couple of questions. It looks to me that it has a 2010 manifold on it. And the head was replaced not too long ago as it is still cast-lock gray. So 1.) Is it possible that a 2010 head would work on the 1010 block and sleeve deck?
2.) Would the 2010 manifold fit on the 1010 head?
I did look up and see that the blocks for the two engines have the same casting # so that does not help and the block that is in the machine appears to be original in my opinion.
This is the first "new generation" I have owned. I did get it running with all new ignition parts and I plan to go through the TSX860 carb, which is the correct carb, and it runs really nice.
If the parts are indeed interchangeable should I even worry about it?
