Yesterday after bush-hogging, noticed fluid dripping from underneath the tractor. It is leaking hydraulic fluid from the center of the tractor almost exactly under the space between the seat and steering wheel where the gear shift to the transmission (1, 2, reverse, etc.) is located. The fluid is draining from a weep hole? in the casing (best I can tell it is a weep hole, there is nothing in the opening and does not appear to be threaded. According to my research,there is normally a cotter pin located here but mine is missing). Thoughts on what the issue is here? Where do I have a leak?
