1951 B Missfiring under load
grampsh1
My B only fires on one cylinder when put under load like climbing a hill in 6th gear at full throttle magneto has new coil points and condenser new spark plugs wires are wire core carburetor has been cleaned and rebuild kit including float needle and seat secret passageway clean any suggestions on a cure
Does she blow any black smoke? You might open the load needle 1/2 turn with each test run until it does blow black smoke to eliminate mixture issues from the table. I would start there. Kudos for the new spark plug wires, too many times they are just forgotten about.
Sounds like the load side of your carburetor is out of adjustment. I would also check the gas flow to the carburetor and / or float adjustment. Check your engine compression cold and hot, possibly a valve problem. I have also had a condenser act in a similar manner. At a low idle the tractor appeared fine. However, when the engine was throttled up the condenser would break down. I thought it was a carburetor problem because I had just put new points, condenser, plugs, rotor and wires on the tractor.
(quoted from post at 19:34:09 07/17/18) My B only fires on one cylinder when put under load like climbing a hill in 6th gear at full throttle magneto has new coil points and condenser new spark plugs wires are wire core carburetor has been cleaned and rebuild kit including float needle and seat secret passageway clean any suggestions on a cure
hanks for all advice I have been thinking spark will verify with magneto from my BR then try plugs if that doesn’t work will put back magneto and plugs and swap carburetors thanks again
I agree with ET. Back in the day our 520 would miss under load.
We kept removed plugs that looked almost new... no carbon. Checked
other things. Finally replaced those good looking plugs and cured
the problem. After that anytime the tractor would miss under load
we just replaced the plugs.
