Weight specs
JamesJTX
Was wanting to mount a spray tank on the front of my 69 4020 wide front row crop anyone know what maximum weight is, dont want to damage and front end parts. Thanks.
300 gal would be max. the double stack weights and 8 weights would weigh about the same . you need big flotation tires and a heavy duty front axel.
Thanks, have 14 ply aircraft tires on it was only going to put a 120 gallon on it and a 200 gallon on the rear.
I run a full stack of 20 front weights on the front of my 4020 at times put the weight bracket off of a 4850 on it .
I have a 158 loader on mine and it will lift 4000 lbs. It will hold that up I just would not run over rough ground except in low gear though.
