Hi, you guys helped me out a week or so ago with replacing a seal and priming an M hydraulic pump, thanks to your help it worked out fine.
Unfortunately I have another M I bought from a friend so I could get the mower and cultivators from it, then resell it. But this one also
started to get hydraulic oil in the crankcase and the the lift was very jumpy. I wanted to fix it before I sell it. I took the pump
apart and the pump drive shaft has sheared off the woodruff key and the shaft is kind of beat up. Tractor serial number is 15456. Parts
book says part number is M503T, Worthington ag parts has one for $55. Do you know anyplace else to get one? thanks again.
