TractorLinks.com
Show Parts for Model:
J D 1946 A Slant Dash
Ron cutler
07-11-2018 15:29:39
I have a J.D. Model A,1946, How do i change the oil pump shaft coupling? can it be done from the bottom of the oil pump or , by taking the governor case apart, any help would be appreciated, Thanks Ron C.
Ron cutler
07-12-2018 14:47:19
 Re: J D 1946 A Slant Dash in reply to Ron cutler, 07-11-2018 15:29:39
Thanks you all, i thought it could be done with out taking the oil pump out , i bet that's a real job, Thanks again Ron C.
david from kansas
07-12-2018 09:48:14
Aren't there a couple of oil lines you have to take loose to be able to drop the oil pump? I have never done it just recalling what others have said.
Old Popper
07-11-2018 18:34:46
Get a couple of long bolts to replace 2 in the oil pump cover, that way it will only drop 3" or so. Make sure you drain the oil first. Take the crankcase cover off the top to replace the coupler.
greenmech
07-11-2018 20:16:22
 Re: J D 1946 A Slant Dash in reply to Old Popper, 07-11-2018 18:34:46
That is a good idea Popper. Ron MN
Old Popper
07-12-2018 10:56:06
 Re: J D 1946 A Slant Dash in reply to greenmech, 07-11-2018 20:16:22
An old 2 cyl JD mechanic taught me that one about 40 years ago.
Waterloo
07-11-2018 17:32:10
The least work and expense to replace the oil pump drive coupling is to remove the crankcase cover on top and remove the oil pump drive cover on the bottom. This will allow you to align the coupling with the cam driven shaft turning the oil pump. You can not replace the coupling without removing the crank case cover.
MikeJM
07-11-2018 17:28:16
You’ll have to remove the crankcase top cover where the starter is bolted to. Then depending on how things look you can drop just the oil pump gear and put a new coupler on and put it back together. If the oil pump body is gunned up or has issues you’ll have to disconnect the line and drop the whole oil pump out.
