Model 35 loader
A 35 was never designed to go on a two cylinder row crop tractor. It was for 2010,1010,430's ect. I have seen them on 3010's and 2510's. You should be able to make it work but will need to some fabricating to the mount that go on the axle both for length and to mount them on the axle. Tom
A GB 800 or 900 is a pretty good match for a 720-730. Neighbor had one on a 720 but didn't need the loader any longer so I bought it from him and mounted it on my 4020 and it is still in use. Two mounting brackets to the frame, clamp rear frame to the axles with a couple of U bolts.
I think the parts book for a #35 shows mounting for a 3010 and I saw one on a 3010, but pretty light for that tractor. I have one on a 430 and about right for it. I think the #45 was for the bigger 2 cylinders and there was a version of it for wide front(can't think of the number offhand)
The # 45 or for wide frt. # 45W will fit correctly.
I have seen more modern loaders on 2 cyl. but are rare. You would have to do alot of bracket work yourself to do one.
If you want a nice loader tractor best to move up a few years out of the 2 cyl. era.
Mike M's advice is good. A 48 loader will fit a two cylinder, but only if it came off of one. I got one with the assurance it would fit my 70. It would be a bolt up job if you had the attachment kit for a 70. I didn't. It's on after a lot of cutting, welding, drilling and salty language. Plus I had to get the ends from high pressure cylinders put on the low pressure cylinders. If I'd have known all that I'd have done something different. A 45/45W will sure work and I had one on the 70 until it explosively disintegrated one day. I didn't get hurt nor did the tractor much, but I sure had something to tell the wife as I shakily poured myself a stiff one when I got home. Good luck!
