I received my new 24 volt starter today that I will use in the 720 D and I was wondering what gauge wire I should be using?
This was a pony motor tractor originally so it has no wiring for a 24 volt system. I do have all the original JD mounting brackets from an original JD 720 electric start. Also in the starter kit came a LIT-200 12-24 parallel switch.
I am not electrically inclined, so I have no idea how this parallel switch works, so can someone explain this to me. When I push the starter button, does everything switch automatically internal in the switch? How does it know which battery to charge. Also where do I connect my amp meter?
I don't have a generator , but plan on getting a one wire alternator.
A simple wiring diagram would also help. Nothing came with the starter or switch.
