46 JD D Fuel shutoff
Working on my sentiment bulb. The shutoff valve has a cork packing that has gotten bad. It looks like it was originally sold as an assembly with the part number AC1080R but is not available. Has anyone found a replacenent. Also looking for connector part number D3019R. Thanks for the ideas.
Here is pix of what has been on my 48 D. 1/4 turn ball valve plumbed from a filter/shutoff (shut off seldom used). Tractor can sit 6 months and not leak any noticeable amount of fuel. I use the ball valve on all my Waterloo builts prior to the automatic oil pressure controlled fuel shut off. Valves are from MSC. HTH George
Nope missed again.
Ok, looking better, this time there is a additional place at bottom of screen that does pix and works.
I doubt you will be able to find any small parts or even a complete stem assembly for that sediment valve,
unless someone with a stash of nos parts has one, if you do though it will probably be too dry to use
effectively.
I tried several aftermarket valves for the dual fuel original system, could never get a positive shut off. I
ended up going with a quality sediment bowl, similar to what would be used on a Farmall H or M Tractor, I
have had good results on other tractors so I adapted it to the D, lost the "original" valve and linkage
setup, but gained a simple and dependable non leaking fuel supply, can send a picture if you're interested.
I have a good used D3019 R adapter if you still need one, email is open...Tom
(quoted from post at 07:15:06 07/13/18) I doubt you will be able to find any small parts or even a complete stem assembly for that sediment valve,
effectively.
