LanceLarrison
Hello!
I am restoring my 1942 John Deere LA tractor.
I have four questions about it:
1) Does anyone have the original wiring diagram for the LA?
2) I am converting it to a 12 volt system but I'm not completely sure what all I need to modify. I was told my starter will be fine. There's no generator on it currently, so I need to get one. What generator nowadays is most original to the tractor? Have any of you converted to a 12V system on an old John Deere tractor before? If so, what exactly did you do and what parts exactly did you buy?
3) What is the correct color for the rear rims of the tractor? I've seen it with yellow rims and yellow wheels in some pictures and in other pictures silver rims and yellow wheels. What is original?
4) Does anyone else have a JD LA? How do you shut it off? Do you just push the throttle lever into the housing all the way past idle to kill it? The guy I bought the tractor off of said that's how you shut it off, however, I've owned several antique tractors in my lifetime and never once have I shut if off that way. Can anyone lend insight into whether or not this is the correct way? If not, what is the correct way?
Thank you for your help! I greatly appreciate it!
