Fletch3130
Good Morning All! 1979 JD 3130 with a CAV DPA injection pump, started leaking externally, so I bought a seal kit and removed pump, disassembled and cleaned it. During disassembly, noticed evidence that top cover has possibly been taken off at some point maybe to put new O-rings on stopper and throttle shafts. Anyway, the small idling spring was missing on the small pin that is attached at top of governor arm which makes me suspicious that the locations of the spring on the governor arm and throttle shaft may or may not be in correct location. I have attached a picture of the data plate. Can someone tell me what the correct spring locations are based on the pic? Also, should it have the small idling spring? If so, where do I find that?
thank you for your help!
Devin
Devin
