John Deere F510 Mower
onemowerguy
New User
I have a F510 mower and the electric clutch wont engage. The clutch switch is fine and if I run hot wire to the clutch connector it engages. Cant seem to find a wiring diagram. Suggestions where I might find one or ideas what might be wrong . Thanks
Check your Electric PTO fuse located in the small fuse block under your seat assembly.If not bad,You need to trace the wires going through your neutral start switches.. Probably a purple or blue wire is not making contact or broken. There is a safety switch on the seat, 2 under the front floorboard that is hooked to your brake pedal.
We had one for a short time. It seemed to be bad at eating deck drive belts. Has yours had any such issues ?
You would have to get your hands on a factory JD service manual to get a wiring diagram.
Weak wiring, find a relay and harness from NAPA and use it on clutch circuit. Youtube has good relay wiring directions.
