Bob Bancroft
Location
Aurora NY
A friend is acquiring a 301A. He says it has a rockshaft. He believes if he could find draft arms and lift arms he could have a three point hitch. Does anyone know what ag tractor would have the same equipment?
I looked for 301A on tractordata and couldn't find it. Yet did a search for 301A, and a tractordata page for it showed up! It says the ag version is 1020.
(quoted from post at 21:17:40 07/05/18) I looked for 301A on tractordata and couldn't find it. Yet did a search for 301A, and a tractordata page for it showed up! It says the ag version is 1020.
To locate 301A or other ind JD models on Tractordata.com one must click on the "industrial" section which I highlighted in yellow
I agree with Tim most any 3 cyl engine '65-'92 JD utility tractor 3 pt will fit
I have a 301A and they are just a 1020 with an industrial frontend. Most had 3 pt. like mine but I guess you could get them without as I have seen several. Same 3 pt. components off 1020 and I expect 820, 830, 1520, some of the 2020 models, ( some had the better lift arms but would work ) and 2040, 2240, and most of those smaller utility models. Just a bunch of tractors that had similar build.
