Jeffrey A.
New User
650 John Deere Tractor
1.Redid all the hoses, changed the fuel filter, and air filter.
2. Had a runaway. had no response to the throttle.
3. Sent the pump and had it rebuilt and bench tested.
4. Reinstalled the injector pump using the same timing shims.
5. The starter went out and I sent it and had it rebuilt. Reinstalled it.
6. Air freed the fuel system, it kind of tried to start, I put a little gas on a rag and it came close to starting .
7. I did not want to burn the starter, so I had my dad pull me down the road and it would not hit at all.
8. I did note that it seemed to have throttle response, when air freeing the fuel lines you had to push the throttle wide open to get fuel flowing to the injectors. And while pulling it down the road I would go from full throttle to slow and you could here the differance.
9. I read that it does not have a kill solenoid.
10. I did replace the thermostart and it works properly.
11. I did inspect the governor, the weights were on it and free, the collar was free and slid back and fourth.
12.And yes I bought it not running!!
History
1.The guy I bought the tractor from said he was bush hogging and it would choke down and it would not pick back up. So he tore it down and put rings ( only )
History
