fixerupper
A friend bought a 3020 gas, I've never seen it, maybe a 3010 that didn't run smooth right away after he bought it. It's a positive ground system so it's an earlier model. It would run well cold but after a few minutes it would start dropping cylinders till it finally died. After a lot of tinkering with it he found out it was ignition, not fuel. After replacing everything he could replace in the ignition it still ran bad after it ran a few minutes then faltered and died. He said it uses a 6V coil, that's what the book calls for so I told him the problem might be between the key switch and ignition. He made some voltage checks and sure enough, it was getting 13.3 volts at the coil and the coil was getting so hot he couldn't touch it. He then said the previous owner had butchered the wiring and it has cut off wires hanging everywhere with new wires replacing the cut off ones so obviously the resister is bypassed. In the shop manual he found out there is supposed to be a resistor wire in the system instead of a stand alone resistor and the distributor should get 7.2 volts.
So after a long winded story, do any of you guys know how much resistance this wire is supposed to have? how much resistance does it need to drop the voltage to 7.2? I told him he could maybe throw a ceramic resistor in there to get him going but I don't know what to recommend. I also told him I think I have an old Chrysler ceramic resistor in a drawer and we could try it and see what kind of voltage we get. I'm going to run over to his place some day soon to help him out and I'd like to make one trip to solve his problem. Thanks.
