Update on LI axle rebuild
David G
I am done fabricating, spindles are tack welded, will get them finish welded this week, then weld up rest of it and paint.
Sometimes I forget to respond when you post an update but I'm always glad to see someone using their brains and fabricating skills on a project like this! Your work looks top notch!
Brandon
I have seen the nice work you are doing on the li and wow what a good job. We need guys like you to be able to make parts like them for the tractors we have and restore. Now every time you look at this tractor you will have lots of pride knowing that you made them spindles on it. I also hope to see more pictures on these and the tractor and thanks for the ones you have posted.
