40u final drives
ben70b
Mine looks different than the part diagram! There is no 35 and when I remove 27 to check the bolts that come loose or disappear I see two bolts instead!
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">There is no 35[/i:654c4848f0][/b:654c4848f0]</font>"
Pure speculation on my part, but the top pipe plug (Key 35) may be the fill plug and the bottom pipe plug (Key 39) may be the drain plug.
a271913.jpg" width="650"
Hope this helps.
I must apologize. I forgot about the change during production. Early models had 1 bolt and later models had two like your's. The parts book shows the serial break.
