4230 John Deere hydraulic pump line
I?ve looked all over the jd parts catalog and can?t find the part number for the plastic drain line that runs from the hydraulic pump to the trans. Mine has a crack in it and I wanna replace. Thanks
Replacement plastic line is #AR87534, look under "hydraulic return lines" in the on-line parts catalog.
If your tractor still has the original little tiny line, you will need a #R64170 adapter fitting at each end.
