4020 rear weights
I need to mount some rear wheel weights on a JD 4020. Are the hole 5/8" or 3/4"? I don't have the tractor close to check or I would measure myself. Thanks.
Rear weights with the odd shaped center hole has timing mark on outer edge of weight that should be lined up with timing mark on cast wheel. After 1st weight is installed then each consecutive weights should be rotated 180° for center hole in weights to align with each other.
