How to pull steering wheel on 2755 SGB?
What kind of puller do I use to get the steering wheel off of my 2755 SGB? I need to replace the plastic slidy thingy in the dash. Any other advice?
Most likely, you need a "steering wheel puller" with a couple of long bolts, likely metric, that fit in the threaded holes in the steering wheel hub.
<img src = "https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//N3497/large/22986962_snx_sun3900_pri_larg.jpg">
I have a steering wheel puller that looks like that, but it won't work. The steering wheel has a hole in the middle of it for the up and down adjustment. It looks to me like it takes a special puller.
Did you take off the nut and lock washer, should be two holes under those, usually off set, use a flat plate and two long threaded bolts with nuts. drill the plate for the holes and thread the bolts into the wheel and tighten the nuts to draw wheel off.
