I have noticed a leak coming from somewhere in the front end of my 630 that is starting to coat both sides of the frame rail. Radiator was replaced three years ago and that looked dry on top and bottom. Took the grill off this morning and it looks like there is somewhere on the steering spindle that is leaking power steering oil. The spindle from top to bottom looks "damp" from oil. Is there something inside that spindle assembly (besides the gaskets) that would be failing that would cause a slow leak? At this point I wouldn't even know where to tell a repair guy to start fixing because nothing looks obvious. Definitely coming from in front of the radiator, and if I park the tractor on a slight grade and leave it for several days you can tell it is running back towards engine. Thanks
