I bought a used JD 2640. Right now it's running OK, but the last couple of times out, it ran fine for a while, then the hydraulics quit. Last time it ran great for about 5 hours, the hydraulics starting failing, so I parked it.....by the next morning it worked fine. Today it ran fine for an hour, then the hydraulics quit again. I let it sit for two hours and they started almost working.....a lot of chatter.
When it's cold, the trans level is a tad over the upper level on the dipstick, and when idling in neutral, a tad under the low. So I go home and admit ignorance and looked up the official way to check the fluid......it says put it in park and have the clutch engaged to check it. I'm not with the tractor now, so I'll check that next time I go to my property.
Would a low level cause my symptoms? or might it be the hydraulic pump?
