730 starter bolt ?
55 50 Ron
A friend's 730 diesel (24 V electric start) has a bolt broke on the starter body end near the flywheel. It looks like made of brass. Parts Catalog says something like " Bolt, Special, 5 used " Reasons, Comments, etc., welcome, thanks. Ron
1/4 x 1 1/2 bolt. I guess I don't understand the question.
They obviously hold the housings together. Didn't remember
they were brass but it's been a while.
I guess my question is:
If it's really made of brass that seems to be rather weak in terms of the load those 5 bolts have to hold. There is obviously a lot of stress there when that diesel is rolling under compression.
I've seen lots of Delco starters of that style, and NEVER one with a brass bolt holding the endbell to the "belly".
Parts catalog shows part # R11020, jdparts subs it to a Grade 2 steel bolt. (Which,obviously doesn't prove what was in there originally.)
<img src = "http://oi65.tinypic.com/qn8w2f.jpg">
There could be dowel pins to prevent wiggle.
Usually the bolts only hold the housings together.
But most starters only have two bolts.
