3020 oil change with 148 loader
nisse
I was going to change the oil on my brothers gas 3020 the other day. This will be the first time since we put on the 148 loader, but it was getting late and I ran into some issues. The crossmember for the loader is right under the plug, I'm thinking I can probably remove a bolt from each side and rotate it down enough to remove plug, or does the crossmember need to be removed? Also is there enough room between the tractor and loader frame to change the filter? Just wondering how big of pain this will be from someone who has done it before.
Thanks,
John
