rockyridgefarm
In order to lift my new to me 6 row front mount cultivator, I needed to either hook up the lift cylinders up in series, or install dual hydraulics. I have lots of points rows. So I opted for the ability to lift each side individually. I haven’t had a chance to try it out, but I now have dual hydraulics, and it’s even a side console...
Tim coulda done it better.
For now, it’s plumbed into the powertrol just in case it doesn’t work. I’ll have to run the powertrol lever, then use the valves. If it works out, I’ll plumb it directly to the pressure and return lines
