Pertronics on a Dubuque
M-MAN
Location
Bostic, NC
Been thinking about going with electronic ignition on one of my M's. Found the kit (1123) on their website for my dist with 12v neg ground which is what I have. I know
some of you have them on Dubuques so how about sharing your experiences.
I have had one on my 430 for years. It works great. It has also been converted to 12 volt with negative ground. I had trouble with points and fouling plugs prior to the Pertronics but haven't since. It has worked well for me, once installed you don't have to worry about points or condensor again. It obviously costs more to start with but points and condensor, if you get a good one, aren't cheap anymore.
I haven't been impressed with point quality myself. Even the echlin and Deere points are pitiful. Got one ordered. Hope the installation ain't too bad.
If I could get David to design me a EFI to go with it I'd be set.
instellation is pretty easy on Dubuque as you can see what you are doing. Instructions are good. If you run into a problem, contact Pertronics much better than guessing and burn something out.
Got their units and coils on most everything gas. Can't imagine fighting points anymore. Those units will work under water.
