I have a 720D electric start, but with no starter motor or generator or battery box. I was thinking about converting it to a 12 volt starter, but after some investigation and questions, I have to believe the 12 volt will really not have the cranking power needed.
My question is... what if I buy a new or rebuilt delco 24 volt starter like a 42MT or similar, and a "single" 24 volt marine battery that will fit in the battery box I have off a regular JD. Also I would buy a 24 volt alternator and 24 volt amp meter. Would this work?
I don't have lights or a fuel gage, so the only thing I need the 24 volts is for the starter. Having a one battery system would eliminate the complex wiring system on the tractor now. What do you think?
