Converting JD 720D electric start from 24 to 12 volts
chas036
I acquired a 24volt electric start 720 Diesel but without the starter and generator. I am curious if anyone here has converted their 24 volt 720 or 730 to a 12 volt starter?
Also can you recommend place to get a 12 volt starter with the correct drive gear teeth to match the flywheel on a 720.
I know all the diehards are going to say to stick with the 24 volt system to keep it original, but I don't want to deal with 24 volts, and besides, the battery box is all rusted out and corroded and I already have a 12 volt and seat that I can put on the tractor. Also I already have a 12 volt alternator that I can use too, so I just need to know the correct 12 volt starter to buy and where..
(quoted from post at 19:55:46 06/17/18) I acquired a 24volt electric start 720 Diesel but without the starter and generator. I am curious if anyone here has converted their 24 volt 720 or 730 to a 12 volt starter?
Are you counting on using two group 31 batteries and 2/00 cables ? Or a spare group 78 car battery that is sitting on the shop shelf and some battery cables from Walmart ? Is three season starting acceptable ? Why are you scared of electricity ?
http://www.delcoremy.com/Starters/Find-by-Model-Family/39MT-Gear-Reduction-Starter
http://www.delcoremy.com/Starters/Find-by-Model-Family/42MT
http://www.delcoremy.com/Starters/Find-by-Model-Family/50MT
With the encouragement of Clyde Wilson (RIP) I have made the parts to modify a Delco Remy 39MT starter to fit the JD requiring a 13 tooth gear and a #3 SAE flange.
