Best starter for 4320?
larryanderson
Probably going to replace starter on my 4320.It could still be the original one.What would be the best one to buy? Thanks!
Nippendenso..they will out last 2-3 Delco's strong and dependable...the little Iskra's I use a lot are a good medium duty starter and they work great on a 3020 because the are short and strong,, but the Nippendenso's are the best of all.
Plus one on the Nippendenso starter. I put one on my 4020 and when I needed one on my 4320 there was no question on what to use. It almost made a different tractor out of the 4320. It starts better than ever!!!
12V , 5Kw Denso part number . http://forums.yesterdaystractors.com/trforum/viewtopic.php?t=879948&highlight=&sid=e87d0fd78fea8668819f5639d9773838
Best thing we ever did was put a nippendenso on our 4320 between that and putting two 12 volt batteries on instead of two 6s problem solved
(quoted from post at 16:44:13 06/17/18) Tim do you mean Nippendenso straight or gear reduction? Think you mean conventional but could be wrong.
The 5Kw Nip Denso listed is a PM gear reduction .
