40 steering wheel
Ohio88
Location
Fairborn, Ohio
Can not seem to get the steering wheel off of this JD 40. After 4 days of pressure with a puller and spraying with PB blaster it has not move at all. Is there a secret. Have not had this issue with an of the other steering wheels We have removed.
You might take it off the steering worm box,
pull the shaft back a couple inches,
put something that does not give between the wheel and the pedestal
and then whack the shaft with the nut just a little bit loosened.
Heat helps!
Leave the pressure on and apply heat to the hub. You might get by with a heat gun or you might need the blue flame wrench.
Thanks for the replies. We have hit it with a punch. I thought there was something hidden holding it. We will keep trying when we get back.
