jd R nose cone
kurt v
How the heck does it come off, removed 2 top bolts but can't find what else is holding it on.
thanks
kurt
Hi Kurt, not sure with an R but my 830 & 820 there are 2 bolts 3/8 X 6 inches long at the bottom of the radiator that hold the bottom of the nosecone. Be careful not to twist them off!!!!!! work them back and forth if nessacary. Good Luck.
(quoted from post at 12:26:59 06/17/18) How the heck does it come off, removed 2 top bolts but can't find what else is holding it on.
thanks
kurt
Thank you Mr Kendall
found the bolts and it's off.
thanks
