2755 Drove with parking brake on
Well you did not help it any!!! LOL You should be fine. You may have to adjust it a tighter as you wore some off the lining. I always wanted the brake on these tractors to started engaging about half way on the handle. So if you pulled it up good and tight it held really WELL/HARD. This way you are less likely to drive off with it applied. Just pulling them lightly will allow you to drive off and not know it easier.
This series of tractors have a parking brake band that is 5 times thicker than any other I have seen. just readjust it and you will be fine. May be change the filter. Al
