attilajohndeere
New User
I purchase a 1975 John Deere 2630 Utility tractor with a 48 loader attached that is probably going to need the clutch disc and pressure Plate Asm replaced. It has the independent PTO feature so it uses the single stage clutch. I have the JD Service manual, TM-1085 for reference. The manual refers to the centering tools as JDE-51 and JDE-52 and JD227 clutch release lever adjusting gauge. I do not have these tools. Can I get by without them or is there something I can substitute in their place? The manual also says that the JD227 gauge has to be modified. Are newer versions of that gauge already modified?
