TractorLinks.com
Show Parts for Model:
2040 steering
larry baker
06-12-2018 18:27:43
My wife has a 2040 that the steering is shot and she is really in love with this,her garden tractor
Well I went on line and looked at a unit and that may be the way to go or whats there to buy to repair the unit
After all the tractors Ive worked on Ive never done a steering sector for one of these tractors but have been informed that I will soon be doing one
Tx Jim
06-14-2018 03:43:17
 Re: 2040 steering in reply to larry baker, 06-12-2018 18:27:43
As others stated check for loose bearings &/or worn bellcrank(key 1) shaft.
larry baker
06-14-2018 03:51:38
 Re: 2040 steering in reply to Tx Jim, 06-14-2018 03:43:17
as stated all the moving parts have been replaced ,drag-link and bushings were bad not the box,thats where we are folks
larry baker
06-13-2018 14:17:18
Jim
The serial number is 245930,the worn moving parts to the steering I replaced for her about a year ago
She uses it to cultivate and I did it for her the other day and was lucky to stay in the back yard
You know the drill,your not out of gas if the needle moves,anyway back to the steering,no leaks just serious play in the box and Ive never done one,do plenty of two cyl but none of these
Tim S
06-13-2018 14:47:46
 Re: 2040 steering in reply to larry baker, 06-13-2018 14:17:18
Have you checked to make sure the steer arm bolt is tight under the plug on the left side??I have seen them work loose..and the bell crank arm on the front end is a problem area too...
Tx Jim
06-13-2018 06:33:29
My reading comprehension failed me as I was thinking "leaking oil". Ditto what Tom stated.
tomstractorsandtoys
06-13-2018 05:41:11
How are all the other steering parts? If all the other parts are loose a new or rebuilt steering box will do you no good. The bell crank assembly under the front end is the most common cause of loose steering on Deere utility tractors. Also check tie rods and drag links. Sometimes the arm inside the tractor can come loose as well. Check over all those parts before tearing into the steering box. Tom
Tx Jim
06-13-2018 05:07:39
If tractor has 3 cyl engine one needs to know if serial number is below or above 266749 to determine if tractor has open or closed center power steering. Shaft can be removed/resealed without removing cast housing from tractor by removing steering wheel then remove large nut then turn shaft CCW to get shaft out of housing so 6 large o-rings in housing can be R&R.
DO NOT disassemble steering shaft components unless absolutely necessary because shim location on shaft is very important for correct operation of PS.
Seal kit for PS is AT315816 Seal Kit - ADD 79.94 USD
Bob
06-13-2018 04:56:50
Define "Steering is shot"???
And tractor serial#?
