John Deere 6300 PTO trouble
tlmkr38
New User
We have a 6300 that while using it last week the PTO just stopped working. I tried to turn it back on and it turned on for about 15 secs then nothing. I have checked the switch
and it seems to be working ok and it will swap the current from one side to the other on the connector at the solenoid. I took the top part of that off and it looks like it works
magnetically or something but had rust on it. Cleaned it and still nothing. What else or how else can I check this. I hate paying the dealer that $120 an hour but if I can't find
it I might have to.
Thanks!
Try swapping the PTO and diff lock solenoid. If that doesn't cure it check the speed sensor for the pto shaft .If you pull the sensor and connect it to a volt meter you should be able to produce voltage by passing a screwdriver back and forth at the magnet end.
Where is the diff lock solenoid. I'll definitely try it. Hexk if that one works ill just swap them till I get the hay up
