John Deere A fan drive
Dwashebek
At the front of the fan drive, just before the fan is a bearing housing with a pipe plug on top. Is there oil that should be topped off or checked?
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Is there oil that should be topped off or checked?[/i:654c4848f0][/b:654c4848f0]</font>"
No.
Take a look at the information below.
a270072.jpg" width="650"
Note that the operator's manual recommends high-temperature grease.
You might consider replacing the pipe plug with a grease fitting.
Take a look at the photos below of the front fan bearing grease fittings on our Model A tractors.
a270075.jpg" width="650"
a270076.jpg" width="650"
a270077.jpg" width="650"
Hope this helps.
