John Deere M PTO
pfwise50
New User
I've just begun using the John Deere M PTO to run a fertilizer spreader. I noticed that the PTO housing is smoking after the first pass in the field. Any suggestions as to what is causing this please.
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">noticed that the PTO housing is smoking[/i:654c4848f0][/b:654c4848f0]</font>"
You might consider checking the level of the transmission oil.
Remove the transmission filler plug on the right side of the tractor.
a270038.jpg" width="650"
Add S.A.E. 90W to the bottom of the threads if necessary.
a270039.jpg" width="650"
Hope this helps.
If it has plenty of gear oil in it then you could have a bad bearing in the PTO quill that is getting hot.
Like James I suspect you are low on oil. Nothing there but a brass bushing so running dry will hurt quick. Worst case is pulling the housing and replacing the bushing and scooping out 60 years of crud from the bottom.
