D water feed block fitting?
Does anyone make the D450R fitting in the block for the water feed valve? Or could someone post the thread size? I think it's 1/4 pipe on top and 3/8 pipe in the block?
Thanks,
Brandon
Hi brandon, The one I have is 3/8 pipe on the block end, and 5/16 compression on the tube side, it is not pipe thread on the end that connects to the copper tube.
The D450R fitting uses a rubber compression sleeve I believe, I do not know where to find them.
I think you could get by with the brass compression fitting shown in the link, it uses a brass sleeve instead of rubber.
I am going to order one to try myself, as the threads on my D450R are boogered up on the tube side...Tom
BRASS COMPRESSION FITTING 5/16
