Another M Question
fourspeed
New User
I got the linkage right (thanks M-Man). M runs really well now. Starts and runs with no smoke. After it's good and warmed up (20-30 minutes), it will puff out a little bit of blue smoke at an idle every now and then. It is random, maybe once or twice every couple of minutes. It doesn't seem to do it at all at any faster speed.
Also, if I throttle down from high to low quickly it will puff out some smoke but only after it's warmed up.
We just changed oil and it's right on the full line. The gauge shows the needle right in the normal area when running.
What could this be an indication of?
Sounds good to me. You could probably tweek the load screw on the bottom a tad and help that but if you're working her a tad rich is better.
