oregonfarmer
My 820 3cyl had a Gresen valve and 2 quick couplers attached to the fenders. There was some fluid coming out to the cylinder I wanted to use, but no real pressure. I took the original valve off and installed a good open center valve on the right side where the factory supplied valve should have been. This tractor must have never had that valve.
I tried to use the valve, but it didn't work the way it should. There are 2 connections coming from the splitter. One connection gave me pressure through to the valve, but killed the 3pt! I put in a tee thinking that would give me fluid to both, but neither one worked. Right now the hitch works with a hose going from one splitter connection to the other (a loop).
I think my plumbing is wrong somewhere, or I am missing a part.
Thank you...
Thank you...
