Richard Harrison
New User
I have a JD 300 with a Roosa Master JDB331AL2405 injection pump. Had it for 20 years, and it has always been reliable.
Recently, it has had starting problems. Crank and crank, no fire, no smoke. I discovered that if I gently tap-tap on the injector pump, I get the "click" and she starts right up. There is good 12 volts on the terminal and the ground strap is in place and secure.
After it sat all winter, now I can't get the "click", even with a 12 volt jumper and lots of taps.
I am thinking the solenoid actuated fuel shutoff is clogged with crud or rusted shut. I am unfamiliar with these injector pumps. My question is, can I take the 3 screws off the top cover of the pump and get good access to the fuel shutoff mechanism? Or will tiny parts and springs shoot out?
Many thanks,
Richard
Many thanks,
Richard
