Questions about adding hydraulic ports to a 4020
boner58
I have 68 4020 john deere and I am needing to add more ports to be able to hook up a batwing rotary cutter. The cutter needs 3 ports and I only currently have 1. I do have my tractor setup for a loader using separate joystick and would like to still be able to use the loader while the cutter is attached. Is there an easy way to add 2 more ports? I am sure that is has been discussed before, so if there is other postings discussing this please let me know.
Thank you
Daniel
SO my supply for the loader comes from in front of the break pedal and my return comes from a line that is next to the hydraulic filter cover. SO I would just need to get another joystick and another tee for in front of the break pedal and then another tee for the line next to the cover?
