Has anyone else had trouble with the terminals coming loose on the new JD cab relays (part number AH98337)? Replaced mine last summer and last night the blower and radio quit. Checked terminals on the relay with a test light and with the switch on had power to all but one. When I touched the wire from the terminal that had no power to one of the others everything worked as it should. The terminal with no power to it was pretty loose and after checking a couple of the other ones were loose too. Got a new relay today and it too has a loose terminal. Just wondered if anyone else has had problems with this and if maybe you have found a better replacement? Thanks.
Oh and I checked the wires hooked to the relay and none of them were pulled tight like they had put pressure on the terminal to make it come loose.
