6115D low oil pressure when oil is hot
MARCORVET
New User
The oil pressure light comes on and warning beeper goes off after the tractor is run for a while. turn it off, let it cool down, it runs fine for about an hour, then repeats the problem. Only does this after getting hot. Cleaned out the oil cooler fins, did not help. Engine temp stays in the normal range. Suspect bad oil pressure sending unit. Anyone have any ideas?
Water in fuel filter also turns on that same light, drain the
water separator and see if that don' t fix it
(reply to post at 14:34:28 06/04/18)
Going to get a new pressure sensor in the morning. Tried draining the fuel filters, didn't help. All filters were just changed week before last. Thanks.
Great,,I will be stocking one of those here...the more we can learn about these new nite mares the better and quicker we can fix them...
