I have a bad leak of hydraulic oil from what appears to be maybe a cracked or blown O-ring on one of the tubes going into the steering pump on my JD 425 Garden Tractor. Does anyone have a copy of an exploded view of that steering pump? I'm confused as to how to get the line off to check what I believe to be O-rings between the line and the steering pump body. Any help in explaining how to remove those lines from the steering pump would be very much appreciated. Thanks. I am assuming its O-ring(s) but not sure at this point. It appear that two of the lines can be taken apart, and then it looks like there are two other lines that do not come off the steering pump? It appears the leak is from one of the lines that I believe can be removed but not sure if steering pump has to be removed or what. First time attempting anything like this. Again, appreciate any help.
