Hello, I am posting about a problem I have with a electronic ignition on my JD 4400 combine, I know this is a tractor form however I'm hoping some one on this form can help me.This ignition system looks to be a replacement for the points and condenser that the combine came out with, It had two wires going into the bottom of the distributor, one goes to the coil and the outher one is missing after I r&r'd the starter, it looks like it went to a relay on the inside of the engine compartment however the pigtail wire that is the same color coming from the relay is hot all the time even with the ignition switch off ,that would mean the wire to the distributor is hot all the time I'm wondering if this is correct way it should be wired, Thanks for any help,Al
