Model 60 Oil Pump
edinmo
Looks like one or both gaskets item #15 and 27 in the attached parts list are leaking. Can I replace those from the bottom of the tractor without getting into the
crankcase and what should I beware of? Thanks for your input.
#27 YES,BUT WATCH THE GEARS They will fall down and the one with the sahft if it drops then you have to go in from the top and align the drive coupling. #15 is alot of work ! lots of little lines to unhook from a VERY tight space to work in.
