Part # D417r fuel line elbow cross ref jd 70 diesel?
Can someone help me out I need to know the sizes of the fuel filter inlet 90 degree brass fitting on a John Deere 70 diesel. JD part number is D417r I couldn?t find a cross reference and was hoping to try and find one at the hardware on my way home from work. I believe one is pipe and the other is flare.
Thanks in advance
You won't find one at the hardware store, as it's a "special" fitting that accepts the "gland and nut" system that DEERE used back then.
Unless you want to cobble something up and originality is not an issue, be glad DEERE still has the fitting available, even if you are not going to get much change from a five and a twenty!
