4020 electric shut off
Neighbor has a 4020 with key shut off solenoid bad dealer says not available. Are they available from another source? What is the alternative?
He doesn't what to upgrade to a newer pump for $1,600
Try to Google part #AT28951,, I'm sure some pump shop has them or can get them,,I may have a used one in the bin with some old parts..
The pump shop I deal with sells one that is adapted from another application. It screws in but the plunger is longer and they make a spacer to make it the right depth. I can get you their info tomorrow if you want. I have installed several with no problems.
