A while back a posted about my Mt hydraulic
pump leaking through the input shaft seal,
I installed a speedi-sleeve as was
suggested and that went smooth. However
after I finished assembly and added some
oil it is easy to see it is leaking from
the plug that covers the other gear. I
didn't take that apart this time and I'm
pretty sure I used some sealeant when I
installed it the last time I had it apart.
Is there any product I can use from the
outside to help with leak? If not I may
have to live with it until fall, need the
tractor for the #5 mower and don't have
much time to rebuild it again right now.
Thanks
John
Thanks
John
